Jim Marshall
Thread starter- Joined
- Oct 14, 2007
- 172
I am rebuilding the raw water pump on my Ford/Volvo 270. I got a new impeller and gaskets. Should I put it back together with vaseline or some non rubber attacking grease?
The circulating pump has never been replaced in over 35 years. Should I replace it?
Last, what kind and temperature of thermostat should I use?
One final note. Everything aluminum on the engine seems to be shedding its paint. The steel is better but has similar problems. Any suggestions on repainting the aluminum and steel after I stripped the old off. I have some two part epoxy primer I could spray on.
Jim
Jim
