FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Have a Alpha 1 second gen with a mercruiser 5.7. Apparantly the outdrive is not sucking water up to the motor to cool it. What should I be looking for?
the impeller located in the lower unit of the stern drive would generally be the first suspicion.
a kinked waterhose could do it too. you should be able to see it from the outside w/o doing anything other than looking. might have to get on your hands and knees though, do you have a seloc manual (for your knees).....
this is a kinked water hose on a 1 drive. i think the genII will look similar. this is port side between the gimble housing and gimble ring, exhaust bellows behind the kinked water hose that needs (has been) to be replaced..
the impeller, you have to separate the upper from the lower to go look at... since your gonna be using you seloc for a pillow, i assume you've got the real oem service manual... it explains how to R&R an impeller in it..
Did it ever cool properly?
What have the engine temps been?
When was it serviced last?
Have you ever overheated?
Bad/ destroyed water pump /impeller, corroded pick up tube, kinked/ collapsed water inlet hose,clogged p/s cooler, clogged thermostat housing,
clogged manifolds/risers
