Cooling water tube - 4hp outboard
dmozel
how do I get the cooling tube out of the motor?
i'm not getting cooling water coming out, and when I blow into this tube (with the lower drive casing removed), it doesnt blow out under the bracket like it is supposed to.
is it just removing the upper casing from the motor block?
Mas
Re: Cooling water tube - 4hp outboard
Try blowing from the opposite direction to force our what may be causing an obstruction.
MAS
