Re: cooling water
Hold your palm just behind the exhaust relief ports in the upper midsection. When the thermostats open, water droplets will form on your hand, if the system is operating properly. Also, the thermostats open at 143 degrees-you should be able to put your hand on the heads, block for 15-20 seconds. If it is too hot to put your hand on it for that time, then it is overheating. The hot horn should sound at 212.
