Core plugs removal 1976 115hp evinrude
Status
Not open for further replies.
raveon
How do I remove and replace carb core plugs in my carb. Do I clean with a good shot of carb cleaner spray?
HighTrim
Re: Core plugs removal 1976 115hp evinrude
Use an awl or punch and hammer, being careful not to drive in through too deep, and pry it out. Others put a bit of grease on a drill bit to keep bits from gettting in carb and drill them, then pry out.
To replace use a hammer and the end of a socket extension or the like to lightly tap it until it seats and spreads.
I like to completely soak the carb, remove all the jets, clean with a couple strands of wire from a piece of extension cord, thoroughally clean, blow out with compressed air, rebuild then re install.
Check out the secret files, it is highlighted in my signature, and read a thread by Tashasdaddy regarding Carb Cleaning.
AlTn
the manual probably suggest drilling a small hole in the center then inserting a pick to pop it out... I use an awl in the center and strike it with a hammer...doesn't take much as you can see how thick they are...they pop out pretty easily...
Craig-
Put a hole in them and pry out. Clean pilot circuits and blow out with air. Replacement plugs are convex and expand when tapped in center. Use sealer.
jimdd810
I am glad to see someone finally asking how to do this. It is an important step in doing a carb overhaul and many people dont do it. Good Job!
BigB9000
sealer?
what kind of sealer?!
Daviet
I don't use any type of sealer, if you seat them properly you should not need any.
HighTrim
Ive seen sealer on some that Ive bought, seemed like they mushroomed it a bit too much and maybe failed to seal. Never actually used it myself.
Craig-
Many rebuilders don't use any sealant. Good old fashion nail polish was the old standby or indianhead shellac, but ethanol eats it. Many small 2 stroke weedeater motors are suffering from welsh plugs unsealing due to the new gas. I now roll the edge through a drop of locktight and install dry.
AlTn
factory manual for 1978 9.9-15 hp..."If the casting opening is normal,apply a bead of OMC Adhesive "M" to the outer edge of a new core plug."...this is before installing the plug...this info is fwiw
Wantbeboater
I’m looking for something resent on this subject. Drill bit went in too far. Do I need a new carburetor?
GA_Boater
Please start a new thread if you want something recent.. This one bellied up 9 years ago.
Closed.
Status
