Correct Idle RPM
kickinchicken
1989 Mercury 80hp, 3 cyl. Oil Injection Sn# 0B165899.<br />Could someone tell me the correct rpm in forwad gear for this motor please.<br />My father idle it down to troll with, I inherited the boat and would like for it to shift into gear without dying.<br />Motor runs great otherwise.
heybaylor
Re: Correct Idle RPM
idle as low as possible without stalling when placed into gear .<br />usually thats about 550-650 in gear .in the water<br />the idle will change from "muffs" to actually in the water..temp and exhaust backpressure are different.
Moody Blue
Shoot for no more than 800rpm to avoid hammering the gears in the L/U when shifting. Ideally if you can obtain 625-725 RPM while in gear in the water you are doing good.
Elmer Fudge
Hi Kickinchicken, according to the service manual, your motor RPM @ idle is 650-700(in gear).
heybaylor
well that's three same answers<br />ya outa be good to go
