Hi All
I have a 1985 GM/Mercruiser 5.0L raw water cooled. Replacing the thermostat (and housing) but have come up with two completely different assembly methods for the thermo and sleeve and sealing rings. Please check the attached diagrams and can you confirm A or B is correct?? Also my T Outlet did not have any poppet valves fitted (has run for 15 years without) and they are no longer in stock - so is it totally necessary to have them? Guess they limit the leg impeller pump from pushing too much cool water up to the elbows at the expense of the circulation pump. Down side could be when they disintegrate with age and end up blocking your plumbing at the elbows? I know this style of thermo housing is no longer in use from 30 years ago, but maybe some with older Alpha1 era boats out there could know the answers.
Many thanks
Many thanks
