Re: correct method of compression test?
Z-man, you can open the throttle (to "wide open throttle") on a motor all you want, if it has no spark plugs in it, and it will not start.<br /><br />You may have to bypass the in-gear safety switches, by using a remote start switch connected directly to the start from the battery.
