71satellite
- Joined
- Apr 28, 2009
- 28
Hello everyone,
I just bought my first boat last week (1986 Bayliner Capri 205 Cuddy, with a Volvo Penta AQ125B engine and 270 outdrive).
I've worked on old cars and motorcycles before (I'd like to think I am fairly competent in the field of automotive mechanics), but am new to the boating world. This forum has been a great resource, but I haven't been able to find a definitive answer to the following question:
What is the correct type of coil, and spark plug wires, to be using for my motor?
When I bought the boat, the coil was bad (leaking oil out the tower), so I took it to a parts store and purchased a replacement. The original said "use with resistor/resistance wire", so I bought one that said the same thing. My understanding is that a points-style ignition requires the correct type of coil (I switched to electronic ignition in my old car about 10 years ago, so I don't remember much about points-style distributors).
Well, now that the boat is running (new coil, and new points and condenser, was all it took) I'd like to perform a proper tune-up. When I priced out the Volvo replacement wires at $200 Canadian (yup, TWO HUNDRED DOLLARS), I thought that I would look into a universal-fit Accel wire set instead. In reading through this forum, as well as the Accel website, I'm concerned about buying the wrong wires.
Did the Volvo AQ 125B come from the factory with "resistance wires"? I read an article indicating they were originally carbon-impregnated linen (not sure if that is true or not). If that is the case, and if I have a coil that requires "resistance wires", should I therefore be buying the wires that do NOT have a copper core (e.g. the Superstock 4000 series with the "conductive high resistance carbon graphite suppression material")? Or does it matter for an inboard motor?
Maybe the first question should be "is it correct to be using a coil that requires a resistor/resistance wires" with my motor? I have no idea where the old coil came from, or what was there before it - I'm making the broad assumption that the previous owner installed the correct part. I did notice that the spark from the high-tension coil wire is NOT a strong blue colour, it is orange. The motor still starts easily and runs smoothly, but I am wondering if perhaps I'm not even using the right coil for my motor.
Also, some posts on the forum suggest that my motor might have come with a ballast resistor. I'm very familiar with those (I have a 1971 Plymouth), and I've looked all through the engine compartment but have not found a ballast resistor. Am I correct in believing that my motor DID NOT come with a ballast resistor? Or am I missing an important part of the ignition system?
Okay, sorry for droning on. I would really appreciate some definitive answers to these questions, and I thank you in advance for taking the time to help me out.
Have a great day,
Chris
Have a great day,
Chris
