I'm in the middle of replacing the impeller on my "new to me" Alpha 1 Gen 2 outdrive. After removing the impeller housing, I pulled the wear plate off and the paint on the gearcase housing is lifting off and there is light surface corrosion under the paint causing it to lift and flake off.<br /><br />Do I need to repaint this, and if so, what type of paint should I use? What surface prep do I need to do?<br /><br />Thanks!
