Re: could a guy pull start a 85 hp e'rude?
About 10 years ago, a buddy and I took a fishing vacation to the great lakes, I left my boat home since his uncle there had a boat we could use. It turned out to be a rather well used 19' trihull with a late 70's 175hp on it. After a day of fishing, and stopping off somewhere to eat, we figured we'd hit one more spot, before heading back for the day, it was out at that one more spot that the starter decided to give up. No amount of tapping or coaxing was getting even one more turn out of it. Luckily I found a small rope in the glove box with a handle on it, and gave it a pull, it fired right up. We used it like that for the rest of the weekend. It didn't pull hard at all, there's a lot of mechanical advantage when pulling on the flywheel rope pulley due to the large diameter. I was pretty amazed at how easy it pulled and how fast it started that way, it actually started better by rope than when the starter was working for some reason. A later and closer look at the boat, (he went up and got it a year later, and found that the wiring harness was rotted pretty bad, his uncle gave him the boat after it wouldn't shut off one day). He too had been running it without the starter working all that time as well. He was in his 70's then, pull starting a 175hp motor.
I think the larger motors are often easier to pull start then the smaller motors, I've got two 18hp motors here that take all I have to pull, yet my 40hp recoil start pulls easy. The smaller the flywheel the harder they seem to be to pull. If you notice the real small motors use a gear driven recoil bendix to turn the motor when you pull the rope, at least on most that I have, which again gives a huge mechanical advantage over the engine's compression stroke.
