Could one of the wiring gurus look over this wiring diagram?
FBPirate95
Starting new with all wiring on my project boat. I'm not electrical expert so I would appreciate someone to look over what I've drawn out.
Thanks.
tschamp20
Re: Could one of the wiring gurus look over this wiring diagram?
way to small to see.
Silvertip
Honorary Supreme Mariner
It appears to be ok except for the NAV/ANCHOR lights. That switch normally needs to be either a three or six terminal ON-OFF-ON switch. You cannot make Nav lights function correctly with a single switch. You can certainly make both turn on but in operation both must be on while under way. Only the anchor/all around light must be on when not under power. A three terminal switch needs a diode added while a six terminal switch does not. Search this forum -- pictures and diagrams for the wiring have been posted many times.
krakatoa
Here is the diagram for NAV/ANCHOR LIGHTS
seabob4
You can also use an on/off/on with a diode...
