could use some help! stator wiring?
matt88
Three wires from stator to cdi and another two to rectifier. To cdi red showing no connection to ground and brown and blue both showing zero resistance to ground. Cdi showing 25.6 ohms from brown and black kill switch wires then showing zero resistance after moving them around. This engine is an m30a tohatsu made from 79-81. Im beginning to get the feeling that its not really worth fixing because a new cdi box is 267.00 and the old motor probably wont be worth much more than that after its fixed but it ran great before the ignition problems so Im trying to find a fairly cheap way to fix it. Dont have a manual,wish I did. I think the cdi is blown but am really confused about the blue wire from stator showing ground. Shouldnt the blue wire have resistance to ground? Or have no connection whatsoever to ground? Thanks in advance.
hondon
Re: could use some help! stator wiring?
It would be great to know what we are trying to help you fix.Make?Model?Something?What is this thing doing that you do'nt want it to do or not doing you want it to?
matt88
[QUOTEThis engine is an m30a tohatsu made from 79-81[/QUOTE]
30hp 2stroke 2 cylinder tohatsu made from1979 to 1981.
matt88
Attempt to clarify:
The timing base on the engine has three wires running to the cdi box.
One wire is red,one is brown,and one is blue. My volt meter shows the blue wire and the brown wire being shorted to ground. From what I have read the brown wire should be the only ground but I am not sure and was wondering if anyone had an idea of what these three wires should generally read. The red wire shows no connection to ground. The blue and brown wires show continuity of about 25 ohms. Was planning on taking it to the shop on saturday and letting a tech look at it but I thought someone may have had experience with working on a stator and timing base here. My engine has a no spark situation. It was running ok then suddenly became hard to cold start. It ran and started fine while it was warmed up but will not start at all now.
hondon
Yes I did ,but I respond to alot of posts on this forum and I,M used to seeing that model ,mani info at the top of the post.You still have'nt shared with us what problem you are trying to solve.
matt88
Found some interesting info. Thought I would post thinking it might help someone else. Not sure but Im thinking that maybe my exciter coil has gone bad. According to this my red and brown wires should show some resistance and it shows none. Starting to think Im the only one that has a 30yr old motor here,lol.:D
Page 1
Installation and Troubleshooting Guide
All rights reserved. Reproduction or use of content, in any manner, without express written permission by CDI Electronics, Inc., is prohibited.
CDI P/N: 119-2402
NOTE: This unit replaces P/N?s: Replaces: 346062601M, 3A1062402M, 3A1062600M.
NOTICE! This product is designed to be installed by a professional marine mechanic. CDI Electronics cannot be held liable for injury or
damage resulting from improper installation, abuse, neglect or misuse of this product.
DO NOT USE A MAINTAINENCE FREE BATTERY
FOR THIS APPLICATION!
WARNING!!! NEVER DISCONNECT THE SPARK PLUG WIRES WHILE THE ENGINE IS RUNNING AS THIS WILL DAMAGE THE
INTERNAL IGNITION COIL. DO NOT ATTEMPT TO START THE ENGINE WITH THE SPARK PLUG WIRES NOT CONNECTED
EITHER TO THE SPARK PLUGS OR A SPARK TESTER.
1. Disconnect the battery.
2. Disconnect all wires from the old power pack and remove it from the engine.
3. Thoroughly clean all ground connections and power pack area.
4. Install the new power pack using the original bolts. It will be necessary to mount the new power pack on an angle using only two
bolts.
5. Connect the spark plug wires to the spark plugs. It does not matter which spark plug wire goes to which spark plug as the internal
ignition coil fires both spark plugs at the same time.
6.
Connect the Red, Black and Blue wires from the power pack to the charge (exciter) coil (Red), plate ground (Black) and trigger
(pulsar) coil (Blue). If the original power pack used a three pin connector between the stator plate and the power pack, cut the three
pin connector off. Strip approximately 3/16th inch of insulation from the wires and put the shields on the wires before you crimp and
solder the connectors on the Red, Black and Blue wires from under the flywheel. Use the wires on the new power pack as a guide
for the correct connector to use.
7. Connect the Black wire to engine ground. NOTE: Some of the older engines used a Brown ground wire while the newer engines
use a Black wire.
8. Connect the Brown and Black stop (kill) wires to the engine harness or stop circuit.
9. Reconnect the battery.
TROUBELSHOOTING
Recommended tools:
CDI 60 OR 33 multimeter with DVA adapter (CDI 511-9773)
Piercing probes (CDI 511-9770)
NO FIRE ON EITHER CYLINDER:
1. Disconnect the Black and Brown stop wires and retest. If you now have spark, the stop circuit has a fault.
2.
Test the stator (exciter) and trigger (pulsar) stator coils as follows:
Red Lead
Black Lead
Resistance
DVA
Red
Black
200-300
135 V min
Blue
Black
30-46
4.75 V min
No Fire on One Cylinder:
If only one spark plug has fire, the internal ignition coil is defective. The power pack will need to be replaced.
High Speed Miss:
1. If the boat is equipped with a Hummingbird I.D. depth finder, disconnect the power to it and retest. If the miss is
gone, switch to a different depth finder. See Tohatsu Service Bulletin # 1200, dated 9/14/1990.
2. Check fuel lines/tank for restrictions, leaks or loose connections.
3. Check fuel pump diaphragms for holes, allowing extra fuel at high RPM?s.
4. Verify correct spark plugs are installed and are not fouled.
5. Disconnect the stop switch and retest. If the engine performs properly, the stop circuit has a fault.
Thank you for using CDI Electronics
