Counter rotating motor
ckb5412
I have a counter rotating 1998 Johnson 175, what is necessary to change it to a right hand rotation motor? If it is just changing the lower unit will a 1994 V6 lower unit from a 200 hp fit the 1998 175hp? Thanks
Benny1963
Re: Counter rotating motor
why are you changing rotation is it a single motor application
bennyb
ckb5412
I have 6 different props for RH and and extra gear case, possibly 2, but no props or extra gear case for the counter rotating. It was just an idea seeing I have to remove it from the counter rotating to service the water pump anyway. There are no cheap props or parts for counter rotating motors.
tashasdaddy
i think so, but Dhadley will know for sure. the rotation difference is in the lower unit. i agree there are no cheap parts.
