bspeth
Thread starter- Joined
- Aug 30, 2013
- 765
1) Does the 303347 oring just set on top of the 303357 lower bearing to driveshaft seal? I see a little cup on top which it seems like the o-ring will slide down into eventually,compromising the driveshaft seal between there and the 303356 driveshaft to crankcase plate.
2) How does the filter in the glass bowl work?The parts diagram shows only a stud and a wingnut for the assembly.
Thanks-B
Thanks-B
