dragginanchor
- Joined
- Jul 12, 2010
- 49
Hi all-
Got a '89 Bayliner 1750 (17' bowrider) with a OMC 2.3L I/O A week ago. Only had it out a few times, time and weather permitting. Good times
Anyway, what is the correct engine temperature? It only gets up to 170 F no matter how far or fast you go. Bad thermostat?
Also, the prop is somewhat chewed up on the leading edges and I would like to get a better one and use the old one as a spare. What would be the best one for it considering--
42 MPH GPS, about 5400 RPM WOT, (WOT range 5200-5600, 2:1 drive)
Not intending to pull skiers, (but possible very rarely) just general cruising and some fishing lightly loaded mostly.
It looks like the factory prop on there and it gets on plane fine and moves right along at about 5000 RPM with the trim down. Trim it up and get the RPM to about 5400 and its about the limit. It starts to cavitate or porpose after that except on very smooth water..
Of course a new prop would be be better than a old dinged up one, but what would be the best for my old bayliner?
Thanks-
Dragginanchor
Thanks-
Dragginanchor
