bondomerchant
- Joined
- Jul 6, 2009
- 47
Re: Crack in engine?
that sux well looks like ya get ta fix it proper after all
why waste fresh oilwhere ya at over here fish
ya but ya thought ya had it only on the outside of the block she will just milk up againOh, I've been reading on this forum that if you have fixed the intrusion area (like I think I did), you can try to get the water out of the oil with an oil change (or 2) to see for sure...
hmmm.... water could be coming in if the crack extends across the top of the block or it could be coming through a cracked head. One other source is the exhaust manifold could be leaking and running back in on top of the pistons (I've had that happen on three mercruiser engines).
CRAP, CRAP, CRAP! No more water running out of the cracks, but after it ran to temp... I checked the oil and it's milky as can be. Does this mean I should not drive it again? May seem like a dumb question... but I thought I'd throw it out there.
But as you got a cracked block already, I would just remove the motor from the boat and rebuild it...
