Re: cracked bellows
Another thing to check for is the upper oil seal on the outdrive. If a lot of water got in the u-joint bellow, then the seal could be bad. You can tell by looking at the outdrive oil, (milky), or if there is outdrive oil in the bellow. Also, check the u-joints for rust.
