1997StingRay190
Thread starter- Joined
- Jan 1, 2009
- 57
Situation. The boat was sitting this winter in New Jersey and the person who owned it previously didn't drain the water from the block. I got the boat back to NC and let it thaw out inside.
One casting plug was pushed out. I did a ghetto leak test by pressurizing the cooling system to 45 PSI, I couldn't hear any leak and after ~ 1 minute there was still tons of pressure.
I changed the oil and after I had all the old oil out I poured 1 extra quart of oil in the engine to flush stuff out and make sure I got all the old stuff out, then pumped out that quart.
Then I put a mobile one oil filter on and ran the boat for ~ 1 hour with the outdrive in a tub of water. I was confident the block was cracked, but now I'm not so sure.
On the oil fill cap there was lots of condensation and I emptied it several times, however after ~ 1 hour of running the oil still looked pretty clean.
1.Could that huge mobile 1 filter be catching most of the water if the block is cracked?
2. Could the block not be cracked and all that water on the oil fill cap is from condensation from sitting so long?
3. Is it possible that the crack is so small that I need to get the boat in the water running high RPM which would pressurize the cooling system with lots of water before it leaks into the oil?
I've been beating my head against the wall trying to figure this out. The person I bought it from said they would help if it was cracked, but they are 600 miles away and I think its best if I find out sooner than later. I'm willing to pay someone to help me get this figured out. Please help.
Thanks
Sean
Thanks
Sean
