Cracked block
wpminc
I have a '91 Mercruiser 3.0 I/O that appears to have cracked on the side of the block over the winter by ice. Pushed out slightly with tiny water dribble. Anyone know where to find a used block or if JB weld will fix? Any suggestions will be appreciated. :(
heybaylor
Re: Cracked block
I have used JB on waterjacket external only <br />what do you have to lose ??
btatum
Re: Cracked block
how easy is it to get to ?<br /><br />if it's not too hard to clear i'd have a good welder close the crack<br /><br />jb weld can get you by but in no way is it a correct repair.<br /><br />a good welder with a tig welder can do wonders<br /><br />have one look at it.<br /><br />GO GATORS
