dannyual767
- Joined
- May 15, 2010
- 273
Re: Cracked Block
I know this isn't a thread about the semantics of engine blocks but I'm just going to stir the pot here on this statement. I've been into high performance for almost 30 yrs and I used to work in a machine shop that built a lot of engines. I've got 10+ yrs of Chevy High Performance, and Super Chevy magazines and none of them call a 4-bolt mains block a truck block. I've never heard that a 4-bolt mains Chevy small (or big) block was referred to as a "truck" block. They are referred to as "4-bolt mains" blocks or simply "4-bolts."
I will agree with you that most, if not all, GM heavier duty trucks use a 4-bolt engine. Your standard, everyday 1/2 ton pickup truck, I'm not sure.
Like I said, just stirring the pot a little
A GM truck engine block is a 4-bolt (mains) block. Now these blocks could have come in a car or a truck. But us GM guys refer to all 4-bolt main motors as truck "blocks". When you are replacing a motor in a GM equipped boat it most defenitely should be a truck block. Cams and heads can be changed to what you need. But a GM boat motor should always be a truck block.
