Cracked Engine Pod Mount
Jmunk
I have a Sun Tracker Party Barge that I discovered has a cracked support brace where the engine pod mounts. I heard a rattling sound and found the cracks, it’s the rear most mounts on both side of the engine pod. Over the years the brace must have gotten fatigued. Looks like I’ll have to pull engine then the engine pod off for it to be welded and reinforced.
jlh3rd
couple of questions.
Is the motor original with the boat? How big is it. How old is the boat.
Do you trailer it often or regularly? If so, do you use a transom saver.
Jmunk
Original motor 115HP. Boat and motor 2007
Boat stays in a slip during summer and travels less than a hundred yards for winter storage. It’s been trailered some without a transom saver, but not much.
jlh3rd
in that case it looks like an age fatigue issue, which suck.
I'd still use a transom saver after fixing. I was surprised at how much bounce I saw on mine without a saver.
Jmunk
I’m not looking forward to pulling the engine pod off for repair but it shouldn’t take too long to pull engine and then the pod.
jlh3rd
yeah
I'd have to look again but my pod is bolted to my "C" channel ribs.
