cracked gel coat
pklakeman
I have found several areas of hairline spiderweb cracks in the underside of my hull. Anything a "do-it yourselfer" can do to fix up. Thanks
Bob_VT
Re: cracked gel coat
Check out http://johnrsweet.com/WEST.html and look under the section listing manuals. I recently picked one up at my local marine dealer. Pretty informative and cheap...about $3.00 for a booklet. They have a booklet that specializes in gel coat repair.<br /><br />Bob
dwarrick
After you read the pamplet suggested the second thing would be to get some color match gelcoat if you try mixing it your self you will drive yourself nuts. You can get color matches coats for most boats from minicraft.com. <br /><br />Take your time and learn to work the gel coat.
