I have a 1984 Achilles RHIB. The Transom is cracking. At some point the previous owner beefed up the transom by placing a stainless steel plate on the inside and outside of the the transom. He drilled holes and bolted these plates on. The crack is starting at one of the bolt holes. <br /><br />I would not mind replacing the transom completly, but I do not know how to remove it from the air tubes or reattach it to the tubes. Does anyone have any suggestions on how to repair or replace the transom.<br /><br />Thanks
