charleyrocknroll2
- Joined
- Oct 17, 2006
- 5
I'm ready to buy this boat and begin repairs on the most obvious problem, a big, honking crack ,just starboard of the middle, on the top of the transom. The boat is a center console, deep vee, with a green or yellow deck floor, supposedly signifying it's in the 70's for a year model. The history of the transom crack comes from neighbors. The boat belongs to a fellow "camp" owner and I got this history from others. Apparently, the owner decided to upgrade motors to a `97 Merc EFI 200 in 1997. He cracked the transom first trip out with the new motor. Now, there is a stainless flatbar, of sorts, bolted across the front side, top of the transom for support. I think it took one more trip out to show him, that wasn't going to work. the boat has been sitting under a carport since. A "boat repair guru" friend told me he could repair it simple enough and went on to explain how. The top of the transom is where the crack is and the plywood is visible, obviously weakened and that's why it cracked. GURU told me, the gelcoat would have to be cut off of the top of the transom and the rotten wood removed, while leaving the shell of the gelcoat intact, digging down until "good wood" was found. Suitable wood, then cut and trimmed to fit down in the slot, glued to the "good wood", and then all compressed together with clamps. REfinishing the top of the transom and minor cracks in the corners, would simply entail reading the directions on the refinishing materials, I would expect. It's this "digging out the bad wood" thing that has my brow furrowed..grin. We have a yard and a half of transom here, and no telling how deep I'll have to go to get to "good wood".I guess my first question would be, what tools are suggested for this type of operation, digging out wood from in between two thin layers of gelcoat? A chisel, of course, but where to find a LONG chisel? Any links to articles on transom rebuilding will be appreciated. I relate well to PICTURES.. hahaha.
The owner has auxiliary fuel tanks laying on the deck, so that tells me there is a problem with the below deck fuel cell, reachable by removing the large center console and deck under it. Hopefully, the fuel cell is cleanable and left right where it is, since I heard cutting out foamed in fuel cells can be difficult. These are the only obvious issues I can see with the boat, except, probably some rewiring. The galvanized, tandem axle trailer will need some figuring out, since it looks like the boat just sits on 2x6's, no real bunks or rollers in sight. The trailer has the lever mechanism for raising and lowering the supports, but apparently that hasn't been used in years, either. We all live within a couple of hundred yards for the boat landing, so no one trailers their boats far here.
It's just that digging with out tearing up the gelcoat that worries me. Then, clamping it all together to make it strong.? I plan on putting aluminum sheet across the back, and over the top of the transom after all of this is complete, before installing the motor. I'd hate to have that chunk of iron fall off 30 miles out in the Gulf of Mexico,taking my transom repair job with it..hahaha.
Hopefully, I've made SOME sense to where someone could tell me, "charley, getcha one of these and 2 of those..etc." I'd love to feel this big, ol' boat underneath my feet, cutting through waves out in the Gulf. Thank you for reading this. charley
