usernamekane
Thread starter- Joined
- Dec 13, 2008
- 11
Hey urvry body! I gotta replace a "roller bearing assembly (#14 in the crank pic)" and "seal (#15 in the pic)". I got the flywheel and plate off so i can see it, and have been told that I can just loosen some connecting bolts to barely crack the case open, enough to pull out the crap and put in the new stuff. Does this sound OK? Should I be worried about doing serious damage by doing it this way (quick-fix)? Its a 1977 35 horse evinrude, and it ran fine till one day it went from great to kaput over the course of maybe 20-30 minutes of running it in the river. Took the flywheel and plate off, saw that there was oil sprayed all over, and saw that the seal was damaged. This is actually the same motor Tashasdaddy helped me out with to get running again (for a while)about a year ago-thanks again. I figured ya'll would be reliable consultation on this, thanks for yer time! I'm not sure what bolts I would loosen, if this is in fact a good idea, so thats what the case pic is for.
