Im slowly restoring a 20ft glastron sierra 199.Im studying to become a ship engineer so I only get to do a little now and then,more in the summer.Im almost finished with the interior and a pretty much brand new engine.
I dont have any pictures of the cracks so I try to explain this the best I can.The Plywood is Thicker in the bilge part of the boat.Im not sure if there even is any plywood on the sides.This is the best picture I have to explain it:
The Plywood in the transom is dry at the holes i drilled to test.The bottom of the transom is a bit "swollen,but im not sure if the plywood is saturated or if they used extra cloth there.The "swollen part extends about 1 inch from the bottom of the transom.I now for sure than the plywood is completely dry where the housing is attached and a bit lower.
My problem is I have a few cracks on the gelcoat on both sides where the thick part ends.And the cracks are far up the transom on the sides,not at the bottom at all.And I know for 100% the transom is completely dry there.The cracks are above water level.
Now my dilemma is what could cause these cracks as the transom is solid.A failure in design?The drive getting hit and the flexing of the transom causing these cracks at the edge of the thick plywood?
The gelcoat on this boat seems very brittle,it has several cracks in the gelcoat,mostly caused by idiotic owners.This is a slow project and I plan on redoing the complete transom,stringers and floor in the far future.But as for now Im planning on reparing all the gelcoat cracks this spring and use it in the summer to get some inspiration to continue with this project.
Whats your take on this dilemma of mine.I dont want to do anything half assed and pay for it later.But its frustrating to have a boat and not get to use it at all
Thanks in advance
Matias
Thanks in advance
Matias
