Thank you, that is exactly what I wanted to know!! A leak down test consists of pressuring the cylinders with air correct? How much psi is too much or not enough?
Compression test numbers in this situation might be sufficient enough as Racer says.
I've ran into situation personally however where compression numbers were even on all cylinders but one cylinder failed leak down test which found one damaged cylinder wall which I was glad to find before spending any money on this latest acquisition.
Usually cylinder inspection with head off and checking through intake and exhaust ports piston and rings condition will reveal what a failed leak down test would indicate.
I just find leak down tests a far better use of time in checking health of cylinders.
This is what I am referring to as a leak down test: "
They do this on a four stroke but same principles apply on two stroke. If you get significant leakage into the intake portion or exhaust, its likely the piston & rings, or cylinder issue. If you can hear the air in the cooling system, it's likely a head gasket leak or an issue with the head.
