crank cross
jim kinser
Will a crank from a '94 v4 work in a '89 block ?
emdsapmgr
Re: crank cross
It is very possible that you can swap them. Even though the crank part numbers are different, both cranks share the same bearing part numbers throughout-even the same flywheel key.
Dhadley
Re: crank cross
Which V4s? Are both cranks from a crossflow? Both from a looper? A crossflow and a looper crank are very different and do not interchange.
jim kinser
Re: crank cross
Both engines are crossflows, the only difference I can see is the '94 has a different lower seal.
boobie
Re: crank cross
The upper d/s seal areas were different between the years. You may have to do some lower crank case head swapping.
jim kinser
Re: crank cross
Found another crank in my junk, this one is the same as the original. thanks
