Cdn20valve
Thread starter- Joined
- Aug 10, 2015
- 57
1996 doni lxc. 5.7EFI tbi MEFI-3
I reinstalled my engine after replacing my spun coupler. I must have been very tired, because I accidentally reversed the battery connection on one battery. Key was off, and battery selector switch was off as well. After a couple sparks on the neg post, I corrected the mistake.
Now the engine will crank and crank, but not start.
I followed the diag procedures in the mercruiser manual:
fuel pump works when jumping relay connection.
fuel pump relay ground was open. i added a new ground to the harness. ok now.
fuel pump ecu supply not supplying voltage to relay. harness is ok for continuity. swapping relays makes no difference. pin from ecu looks good.
engine will not run even on starter fluid.
i have a terrible feeling i fried the ecu. is there any other checks i can do?
btw all three fuses are intact.
