crank wont turn
rob935
hi guys i have a volvo 430 a (4.3 v6) its a 1992 had it running fine over the weekend no overheating of drop /rise in oil pressure however i noticed the alternator belt was a bit loose so i tightened it up, tried to staart the engine but the starter was engaging with the flywheel but the crank wouldnt turn?? i have checked all the batt cables the battery itself has a full charge and the starter is only 3 weeks old!! any ideas
tommays
Re: crank wont turn
Pull the sparkplugs ASAP and see if you got in any water :( <br /><br /><br />tommays
I/O WALDO
Re: crank wont turn
Sounds like hydro-lock! take the plugs out and try again.
rob935
Re: crank wont turn
tried to turn the crank by hand but it didnt budge...will take the plugs out and see if theres any water so !!How would the water get into the cylinders ??
I/O WALDO
Re: crank wont turn
Usually cracked exh.mans/risers. or bad seal between mans. and risers.
Don S
Re: crank wont turn
Bad manifolds or risers or failed riser gasket. Leaky valves and a lot of idling, Blown head gasket, etc.<br />If you were in salt water, speed of getting the water out of the cylinders is absolutly necessary.<br />Go check it NOW.<br />If there was water, crank the engine with the plugs out, get it dried out and run the engine.<br />If it's still in the water, remove the impeller and run the engine for a about 15 seconds without water. Just to dry out the cylinders. Then get the boat out of the water to do the troubleshooting.
rob935
Re: crank wont turn
thanks don the boat is out of the water but its an hour away so will be tomorro after work when i can get to it...only been using it on fresh water and have just fitted two new manifolds and gaskets both to engine and risers, finding it strange as the boat was running very well then suddenly wouldnt start..
I/O WALDO
Re: crank wont turn
Hydro-lock story,My 93 502 efi mag and I were out 4 a cruze one day when I shut her down to just chill out in dee rivah 4 awhile when,as I tryed to restart,I was hydro-locked!! Bummer!No previous warning,no problems! It was gittin dark,20 miles from port and impatience insued so,I kept tryin to bump-crank it hopin the water wood leave,NOPE! Broke a tooth!Called a friend,got back to port 4 hrs.later.Next day pulled off the STAINLESS STEEL merc risers.and decided the man.mating surface was corroded too narrow to seal to the risers properly so I replaced the mans.,new riser gaskets (risers looked like new)and installed the risers.FIXED!?? Turned the crcnk to a good spot and fired it up Great!Went to our overnite hole,tyed up to buddys,shut her off,and stayed fer the nite.Next am,Hydro-locked!Pulled plugs,cleared cylinders,reassembled and off we went.Back to the drawin board!Pulled the engine,replaced the ring gear(and starter,I broke that on the LAST attempt to start it!)And got the risers pressure tested,fine!Whats wrong!Only gets intrusion on one side!I fixed it butt what did I do!!HUH!It was the damn s.s.riser!
Don S
Re: crank wont turn
Being fresh water you should be ok waiting.<br />It also may not be water causing your problem.<br />A bad starter, engine problems, drive problems are all possibilities. Try to turn the engine by hand with the plugs out.<br />If you can't turn the engine with the plugs out, pull the upper gear box off the drive and try it.<br />I have also seen the bearings in the engine bellhousing lock up and prevent the engine from turning.
rob935
Re: crank wont turn
thanks don..the drive seems ok however i cant rule it out just yet.. the starter is brand new and the engine was running very sweet so thats why im so stumped !! but i have a suspicion that one of the riser gaskets may not have sealed properly so will double check that thanks again..
rob935
Re: crank wont turn
thanks once again the power of iboats forum wins out... took a trip down to the boat after work today ..took the plugs out and found water in the middle port cylinder turned it over with no problems so should be sorted thanks thanks again guys what a relief.<br /><br />also found that the riser gasket seems to be bad (put on brand new a week ago) it was soggy and out of shape!! will replace and use some gasket sealer 2 ?
