crappy controll lever upgrade??????
riskibusiness
Hey guys I have a 1980 wellcraft 170 bowrider, 470 mercruiser. I have the old style control lever, and like all of them mine doesnt like to go into nuetral. Is there any way to replace it with a newer style that has the nuetral trigger instead of the push button?
starsnstripers
Re: crappy controll lever upgrade??????
You can upgrade it but it might require rewiring your trim tilt. Is your trim tilt on your shifter or dash?
Don S
Are you sure your problem is the control, or is it a cable problem? The control itself is seldom the problem.
riskibusiness
Don I should have been more discriptive. It goes to neutral with no problem. Its the fast idle button for revving in neutral that is the problem. I have the one with the button in the middle of the shifter pivot point. From what I have researched these are notoriously bad for this. And my trim control is on the lever stars> I assume that will be easier right?
