Re: Crazy thought for fresh water tank
Pvc pipe water tanks are a good idea and huge with 4x4 tourers. You can make any combination to make the idea fit anywhere.<br />Im atually going to fit a bladder type of water tank to my 5.5 plate boat. I can stuff it through the little inspection cap in the transom. I could cut a hole in the alloy floor but the carpet is glued down and the fuel tank takes up the space where the weight of a water tank should be placed in a boat.<br />I'll fill the tank from the same tube that will be the outlet water line that will be hooked up to a good fresh water pump.<br />This is where it gets interesting. The water tank I will be using will actually be a 54" ski tube plumbed to suit. The good thing about bladders is that they will take the shape of any area that they are in.<br /><br />Tads
