Creamy gray stuff in exhaust port.
tabbott
I just pulled the lower unit off of my 40 hp ELETB. In and around the exhaust port was a creamy grey colored stuff. Kinda like whipped grease. I recently ran it on the lake. It was a little difficult to start and idling erratically but I figured that sitting unused was the culprit for that. After some time it began running smoothly and starting much like it always has. Any suggestions concerning the milky, creamy, residue?
tabbott
Re: Creamy gray stuff in exhaust port.
I think I found the culprit. The lake I was running on was an Idle speed only. I believe the stuff was there because all I did was idle all day. Make sense?
tashasdaddy
exhaust, unburnt fuel and oil. mixed very common.
tabbott
Thanks fellas. I'm glad it's normal.
Evinrude15
That creamy grey stuff would be a mixture of Oil, Fuel and WATER. It is possible that your exhaust cover may have a bad gasket.
tabbott
I am keeping an eye on it. However given the circumstances I am going with the prolonged idle at the lake. I'll post if I find the same thing after a long run at WOT.
flabum
Check your gear oil, you could have a gearcase leak.
fish56
I had a similar concern with my 9.9 Merc.. It was first thing this year, after having the motor unused for about 2 years. I forgot to consider the fogging oil that I used when I put the motor away.
