Crestliner Help
hribarj
I have a 2001 Crestliner Fish Hawk. I am trying to figure out where the fuel sender is located. A few years ago there was a recall because there wasn't enough flotation in the rear. The dealer put a slab of flotation on top of the gas tank so I can't see anything. If I knew where it is located I could cut into the foam to check the wiring. I want to make sure the fuel gauge problem is in fact the sender before I take the entire boat apart.
