crimps for Connection Plugs
bob johnson
I want to rebuild a plug connector for my control-motor harness. It is the 5 or 6 pin main trunk. The connection is shorting out and I am losing continuity and i am sparking and burning the housing.( i can smell it)
is there a place i can buy yhe factory style male and femal connectors that are used in the plug????
right now both sides of the plug have been splices because of bad wires and then the connector pins went bad, so i have a lot of spliced wires...
Id like to rebuild the plugs from both ends and remove the splices
thanks
bob
bob johnson
Re: crimps for Connection Plugs
found the pins that are in the connector from the motor.
cant seem to find anything from the control from the 90's
only 2004 and newer
dont know if the pins in that plug are female or male...
but i need to find both sets
bob
