Re: cross reference: omc140 starter
catfish1,<br />There are only a half a dozen different Chevy Starters......<br />There are the Straight bolt pattern,+ the staggered bolt pattern.... <br />For the Large, or Small Flywheels......<br />There are the Direct Drive starters(these are the starters you saw on your Daddy's car).... <br />These are split into Automotive + Marine... The difference being an added plate in the main housing of the Marine starters to Shield the Sparks..... <br />Then there are the newer Hi-torque, or Mini-Starters(these are the little japanese race car looking things, that are Really the way to Go)..... <br />In these starters the motor is Already sealed from the bendix drive, So, They Are In Fact Interchangable(auto or marine).......<br /><br />SOOO,huminski is Actually Right...... To a Point.... <br /> <br />In my NAPA book it shows your starter;<br />Reman......$205.00 list $126.49 jobber #18-5900<br />New........$250.05 list $155.82 jobber #18-5911<br />New MiniStarter..$236.34 list $150.64 jobber #18-5913<br />In the Jegs catalog they start at about $140. + Go Up from there.....<br /><br />If you "Sweet Talk" your NAPA guy, you Should be able to get down between the two prices I listed.....
