cross reference: omc140 starter
catfish1
i need a starter, i went to napa and they say the starter is $209.00. i know this motor had to be in a car, so i'm wanting to know if anyone knows of a year & make of car that was produced with this motor block (79 omc 140 four cyl)the starter is a delco. thanks!
TwoBallScrewBall
Re: cross reference: omc140 starter
An auto starter will not meet CG specs, and could spark an explosion. There's a reason the marine starters cost more.
catfish1
thats BS! huminski. this same starter was put in automobiles, and i'm just wanting to find out which ones.
Doug Durako
Here we go again.<br /><br />Catfish1--you might want to search this board for phrases "Marine parts, non-marine parts, and explosions." You will find some interesting reading.
elpaso
Go to ebasicpower.com a marine parts dealer.<br />The correct marine starter is $139.00
elpaso
2nd post - yes I know which auto engine <br />starter will work - but I will not tell you.<br /><br />I don't want to read about you, and the fire in the paper.
catfish1,<br />There are only a half a dozen different Chevy Starters......<br />There are the Straight bolt pattern,+ the staggered bolt pattern.... <br />For the Large, or Small Flywheels......<br />There are the Direct Drive starters(these are the starters you saw on your Daddy's car).... <br />These are split into Automotive + Marine... The difference being an added plate in the main housing of the Marine starters to Shield the Sparks..... <br />Then there are the newer Hi-torque, or Mini-Starters(these are the little japanese race car looking things, that are Really the way to Go)..... <br />In these starters the motor is Already sealed from the bendix drive, So, They Are In Fact Interchangable(auto or marine).......<br /><br />SOOO,huminski is Actually Right...... To a Point.... <br /> <br />In my NAPA book it shows your starter;<br />Reman......$205.00 list $126.49 jobber #18-5900<br />New........$250.05 list $155.82 jobber #18-5911<br />New MiniStarter..$236.34 list $150.64 jobber #18-5913<br />In the Jegs catalog they start at about $140. + Go Up from there.....<br /><br />If you "Sweet Talk" your NAPA guy, you Should be able to get down between the two prices I listed.....
catfish1
ok, but i'm wanting to get another "car" starter to rebuild this one with. the brush springs seem to be part of the outer cylinder, and two of the spring clips on my starter are broken off, thats why i want a car starter. the outer cylinder and brush assembly should be the same on car or marine applications.
catfish1
nevermind, a friend of mine stopped by with a car starter, i just finished putting the brushes & spring clips in and it works good now. thanks for the replies! :) <br /><br />ps. huminski, sorry i doubted you. i should have been more clear of my intentions.
