crazy charlie
Thread starter- Joined
- May 22, 2003
- 5,749
Hi guys,the motor is an 84 115 rude.the problem is 115 readings in three out of four cyls.The starboard lower cyl is only about 25.It is a shock to me with the care i take of the motor.Never run hard,never even ran warm.the idle was low one day so assuming it was time for a carb rebuild,I did a comp test first.I was stunned.The motor runs fine with a higher idle and when on plane the power seem to be the same as always.I am going to try a decarb on the low cyl as suggested by a member and want to know which side of the carb to spray in to target that cyl.Someone mentioned that these carbs are crossflow???? Charlie
