rothfm
Ensign
Thread starter- Joined
- Sep 26, 2006
- 918
Can can anyone tell me the path of those relief holes? I understand the impeller path and have the OEM diagram. What happens with
the relief holes/path/poppets? Really looking for input, as i've been working this cooling issue awhile.
1993 Johnson 115 bubbleback.
My issue at the moment is no flow at all out relief holes, on plane and warmed up. At Idle, i get a slight mist and light exhaust warmed up. Initially, this new to me motor had no stats, and bad diverters. Replace everything and It looked good on hose, albiet one side was a bit warmer than its 140 port side. Thought I was good to go!!!!
First in water test...Overheated at the ramp while I was tied up and monitoring with IR gun. Went from cold to 190-Both sides(new pump kit and great pee). I let it cool to 120, restarted and temps held at idle at 140-155 +- So we went out, and temps remained in spec. HOWEVER, ABSOLUTELY NO FLOW OUT RELIEF HOLES AT SPEED. I dont understand. Stats appear to be working. Is the path for this Onrush of additional "speed-water", the same as the pump flow basically? On muffs I have good even flow out the head hoses. And on muffs all exhaust and water seems to exit where it should.
I'm wondering if my initial overheat at the ramp was a vapor lock, as it cleared upon restart and never came back. Incidently, I have a couple of powerhead exhaust leaks making oily streaks down the leg. I thought it was minor, but could that be part of this problem?
Arggggg.....thoughts please
