Boattest dot com probably has a full write up on your boat.
just listen for that sweet spot. every boat has one
You mean when the kids stop yelling, "faster! faster!" and the wife hasn't given the "you're going too @#$ fast, SLOW DOWN!" look? That sound???![]()
Cruising speed is mostly dictated by engine RPM. That motor will be singing nicely at 3200 to 3500 RPM which will put it right at it's best volumetric efficiency and likely have the boat cleanly on-plane. More than that and you'll be pushing it past its sweet spot and using more gas. Less, you'll probably be using a lot more gas.
might be confusing terms... For best volumetric efficiency, you need 100% wide open throttle. Its a ratio of how much air is going into your engine, vs theoritical max amount based on displacement. (a 5.7l engine sucking in 5.7l of air is 100% volumetric efficient, which is essentially impossible without a turbo or some really clever tricks of the intake, which are only good at very specific RPM's) A throttle plate destroys volumetric efficiency, that is its purpose, to throttle the engine.
In terms of VE, the absolute best engine is one that runs at 100% output all the time, and doesn't even have a throttle plate in the way to slow down the air. That is the reason VE isn't generally talked about in terms of economy, because you generally don't have the luxury of sizing an engine perfectly to the load. In most real world applications you need a throttle plate.
The OP's engine is maybe around 30% VE at partial throttle steady state 3200 rpm, and maybe 85% VE at WOT max rpms.
thanks for the link, so it looks like the sweet spot of the engine regardless what you have is 3000 rpm.. i might have to go sith ss laser prop or somethingMax RPM is 4400-4800 RPM. You should select a prop that allows you to obtain that range and this will be your maximum speed. Cruise speed is usually considered to be 1/2 to 2/3 of max speed for pleasure boats. For instance a bass boat might reach a top speed of 70 mph with a cruise speed of 35. Pleasure boats typically have top speeds in the 40-45mph range and cruise nicely at 28-32 mph. Typically you want your engine to be running at the peak of the power arc at cruise speed. This will produce the least amount of stress on the engine and provide good fuel economy. I'll guess but I think your peak should be around 3400 rpm.
Edit: I wasn't too far off on my guess.. Check out this link : http://www.mercurymarine.com/engines/engine-tests/mercruiser/
