Cruising RPM Stringer 800
allen.st
Re: Cruising RPM Stringer 800
SC, I did that water test per the books I have and it only took about 7 seconds to pump a gallon, book said something like 30 or 40 seconds (they are in the boat now and it is 30 here now "LOL") The cap on the trunion is on with a new washer in it, I and not sure I am going to use the hose connector on the outdrive again, that might be how I filled the crankcase full of water once. Had hose hooked up and turned on full before I started it. (4 oil and filter changes fixed that)
allen.st
Boomyal: what is a good penatrant? I am sure this is not the first stuck thing I am going to run into.
Boomyal
There are many, SDT. Liquid Wrench, PB Blaster, Zep to name a few. Definitely a must have if yer werking with nuts and bolts.
allen.st
Boomyal: thanks, at first i thought you were calling me nuts, then I put my glasses on "LOL" I will pick some up.
KaGee
PB BLASTER is a must have in any Hacker's tool box. Right there along with the duct tape! ;)
