Crusader/Caddilac Headgasket
enn858
Hi from Denmark
I have tried everywhere to get a Headgasket kit for my crusader/cadillac V8 model RH300 serialno 3046 it`s from 1965
Can anyone help me with a source for this part??
Thank you very much in advance
JustJason
Re: Crusader/Caddilac Headgasket
try to simplify it....
do you know the block size? a 305 or 350? do you know if it is a chevy block or a GM block?
Try posting a few pictures, that may get you a better answer.
daydreamer1252
Jason,
It's probably a Genuine CADILLAC Engine not a Chevrolet in a Cadillac costume. That didn't start until later. Had a friend of my stepfather who had a 300hp Cadillac in a Century in that period of time. Pulled 7 skiers at a time and still seemed ready for more! :D:D
May not find a readily available MARINE head gasket for it. May not even find a readily available automotive gasket for it. Long time ago ;)
I'd start at NAPA online. May need cylinder bore to get you the displacement of it and go from there.
Good luck.
enn858
Here is a Picture of the engine and the boat:
79Glastron
Wow, dual quads, Carter WCFB's at that. That engine could be almost any displacement, ranging from 390 on up to 472. You may have to get a casting number off of the block to find out what engine it is. A head gasket should be easy to find, getting a "marine" gasket may be harder.
enn858
Hi again
I still havent located the headgasket
Here is the numbers I can see on the engine
1473267
6061055 LC
LLI
Can anyone help locate the parts?
enn858
My friend (who owns the boat) and I am just about to give up trying to locate/find headgaskets for this engine
We are prepared to pay a good price for the right headgaskets - can anyone help us saving this old engine.
rodbolt
you may try contacting crusader directly or look at some of the older Chris-Craft sites.
several marinizers used the cadillac engines of that time period.
also do some research on avalible engine sizes from cadillac in the 63-66 year ranges.
I am quite sure that in that time period not much was actully marine.
but some of the sites dedicated to older hulls such as Criscraft,Cruisers INC.,Gray Marine and a few others will turn up something.
many folks are getting into the restoration of these old rigs. some are stunningly well redone.
I know the Mariners Museum in Newport news Virginia has a staff of restorers for their ChrisCraft Exhibit and they may have a source.
