sprintflyer
Thread starter- Joined
- May 20, 2002
- 16
I am running a mariner 150 mag 2 on a 19' 296 sprint with a 25 pitch 4 blade cupped shooter.I have about 30-35 psi water at wot but my rpm are a little low and I can only get about 55 mph (speedo) with this set up. The tail is about as high as the cowling when I am trimed out but I can make it go higher if I keep triming. I am running a precision propeller 6 inch jack plate. Is this prop suppose to be run part of the way out of the water and how high should my motor be in relation to pad.<br />Thanks,<br />Sprintflyer
