Curing unwaxed poly resin
jeffrey.bean
I’m glassing over a bunch of holes in my top cap. I plan on sanding down everything, to re gelcoat and non skid.
Can I use any paint to cover and cut off the oxygen to the glass, for a full cure?
Again, it will all be sanded off, faired and gelcoated.
Thanks
I use PVA which can then simply be washed off. However yes. you can also just put a plastic bag over it or tape it off with painters tape.
jeffrey.bean
Thanks for the reply, as you can see, I have a lot of patches, figured it would be easier to slap some paint on them, then bagging them all.
I will pick up some pva, next time I pick up FG supply’s.
Thanks again
I spray PVA thru my spray gun over the surface
