froggy1150
Ensign
- Joined
- Nov 3, 2017
- 908
They have cheap ones at harbor freight if you have one of those near you
News Flash . . .
Other ideas?
Other ideas?
Sounds like my kind of luck. Dang that sucks - no pun intended
The vacuum pump I have ate some resin also. The new pump was thrown in the trash because the po was mad he did that. I fished it out, disassembled it and soaked it in acetone. Some bronze wool to clean it up and now it works perfectly.
There are times when I think if it weren't for bad luck, I would have any luck at all.![]()
Ted, have you had a chance to pull the other pump apart? two pumps on-hand would aid in success in the event you suck up resin again
