monte100727
Thread starter- Joined
- Jun 3, 2009
- 8
I have a 1978 johnson 85 hp, did not run when I got it with a boat for cheap,compression was 112-118, so I insalled new water pump,and rebuilt carbs and with new plugs she was running good,installed new fuel pump,all four coil, one power pack,and the rectifier,motor ran great top speed on the 1985 cajun was 41 gps light load 38 heavy but with four batteries in the back it was a little slow out the hole,not having much in this motor I found a complete hump back exhuast with tuner and intake fillers that I installed with new gaskets total $100, now the issue is the carbs, as this motor is only 3.375 bore it will not move as much air as the 3.500 motors so I need help,I got it up and running pretty good with a 61 jet and enlarging the vinturies from 1" to approx 1 1/4" by hand grindding,first time out today, she had improved hole shot and it felt fast on top end but I forgot gps in garage so I really dont know,but she would start coming out of plane below 3300 rpm so I guessing to much carb for half throttle,I am going to get a set of possibly 1 3/16" carb,any thoughts,thanks.
