Hey guys, I have a cut in the cap and top section of my 01 Crestliner's transom, results of thieves trying to cut out the drive. I want this welded up, but don't know if this can be welded with the plywood transom still in place. I was thinking of backing the cut with 1/16" aluminum plate and then having the cut welded up, but don't know if a welder will touch this since they will be welding on top of wood. I've never welded aluminum, but know if it was steel it would be a big flaming mess
The cap is about 2 1/2" wide and cut going down the transom is about 3-4".
If this can't be welded up with the plywood transom in place I would like to find another way to repair the cut; epoxy, fiberglass, DuraFix, 5200, ??? What do you think will fill the cut and not pop back out again or crack, anything? This is an I/O boat so it won't have as much stress on the transom's top as an outboard boat.
If I have to remove the plywood to weld it up, I'll need to completely remove the beige colored cap (which is welded in place), remove the transom plywood, weld up the cut, weld the cap back together, re-install the plywood and then weld the cap back in place. It's going to be a royal PITA to remove the plywood so I'm trying to figure out how to get it done without removing the transom plywood.
thoughts and suggestions?
