cut wire in front Panal
Status
Not open for further replies.
mcgill
Hello
I Just Got A 87 Winner Bass Boat the former Owner Said The Panal In Front Of The Boat Did Not Work,i Got The Boat any way,,,, Open The Panel I Found 2 Missing Rocker Switches One I Do Not Know What It Is It's Called A Court Lt. And The Another Is A Aerator Auto ,charger Fuse All Where Missing,i'd Like To Replace The Switches, But I Do Not Understand The Wiring There Are 2 Orange Wires 2 Brown wires 1 Black Wire How Can I Wire Those Switch Up i think thay are for som type of pump system.
thank you
mcgill
Hello
thank you
Dunaruna
Re: cut wire in front Panal
You will need a multi meter and start doing some testing.
The court light is probably for the light just above the charger fuse. An aerator is a pump that is used to feed air into a live bait tank.
Can't help with the wire colors although black is usually ground. You need to probe these wires before you connect.
Chris1956
On my '88 SeaRay the orange wire was fused +12V for dashboard accessories. You might trace it back to the fuse block. The brown wires are likely the ones that go to the individual devices. Black is usually -12V or ground.
tashasdaddy
also please loose the CAPS, make it hard to read. multiple posting is also discouraged on the forum, it wastes people valuable time. thank you. but patient, when some one has an answer they will post it.
Status
