Cut wire on top of coil pack
DuKn
Bayliner Capri 1850 Mercruiser 4.3l Alpha one gen 2
Was pulling trim wires for my new trim sender and limiter and notice a cut wire on top of my coil pack. Trying to figure out what it was, boat seems to run fine.
Mc Tool
Connected to coil+ , Could be the remains of a ballast fed coil set up . That piggyback connector dont look stock ..
Mc Tool
Well I aint no expert on Mercruisers but if the motor runs well Id say it was ok . Put it this way :) If I bought that boat used I wouldnt be bothered at all by that . If the joint was made by some bogan twisting the wires or sticky taping them together Id have a better look but whatever it is / was it looks like someone did a halfway decent job .
DuKn
Great, and yes i’m the third owner of this boat. Thanks for the help!
first, that is not a marine connector, that is one of the insulation displacing splices you find at places like walmart.
It is not factory, it was added by a prior owner for unknown reasons.
I would remove the splice, and i would put heat shrink over the damaged insulation.
